Bike Finder · Giant
Giant Reign Advanced E+
Giant
Reign Advanced E+ 2026
CurrentEnduro eMTBAgeing · 4.5/10iFreshness 4.5/10
Carbon enduro eMTB with SyncDrive Pro 3 motor (90Nm/800W) and 560Wh battery
Motor
Giant SyncDrive Pro · 85Nm · 500W
Battery
Giant EnergyPak Smart 560 · 560Wh
Travel F/R
180/170mm
Wheels
29F/27.5R
Frame
Full carbon
Weight
22.3 kg
Price
From £7,499
View the Giant Reign Advanced E+ on Giant’s site
Giant Reign Advanced E+ 2026
From £7,499
EMTB Forums verdict
The Giant Reign Advanced E+ 2026 is the all-new carbon version of Giant's flagship enduro eMTB, rebuilt around the third-generation Giant SyncDrive Pro motor (85 Nm torque, 250 W rated, 500 W manufacturer-claimed peak, 2.75 kg). Travel is 180 mm front and 170 mm rear on a carbon Maestro suspension chassis with a 560 Wh removable Giant EnergyPak Smart battery. Three trims from £6,499 to £9,999, head angle 62.6 to 64.0 degrees depending on size and flip-chip position, reach 426 to 515 mm across the unusually generous 26-position size/configuration matrix. Claimed weight 22.7 kg. The community read in one line: a sharply-priced carbon enduro from a brand with a deep dealer network, undercutting the Bosch CX competition while running Giant's own in-house motor ecosystem.
Drive system and range. The SyncDrive Pro is Giant's third-generation in-house motor, manufactured for Giant by Yamaha. 85 Nm torque puts it at the lower end of the full-power category by 2026 standards (DJI Avinox M2S is 150 Nm, Bosch CX Gen 5 is 120 Nm), but Giant has focused on smoothness, low motor noise and integration with the EnergyPak Smart battery rather than chasing headline torque. The 560 Wh battery is on the small side — most rivals run 720 to 800 Wh — and is removable via a downtube hatch for off-bike charging. Real-world range will sit in the 35 to 50 km territory in mixed terrain on Trail/Boost mode, with bigger 800 Wh packs available as an upgrade on some trims.
Geometry and handling. The 26-position size/configuration matrix is the standout feature here. Giant offer multiple flip-chip positions per frame size, so a Medium can be configured Low (446 mm reach, 62.6 degree head angle), Mid (450 mm / 63.0 degrees) or High (456 mm / 63.1 degrees), with the chainstay shifting between 442, 443 and 450 mm. Reach ranges from 426 mm (SM Low) to 515 mm (XL), wheelbase from 1226 to 1324 mm. Head angles are properly slack for enduro use, especially in Low position. The Maestro suspension layout is one of the best-developed in the industry.
Build and value. Three trims, well-spaced. The base trim at £6,499 (22.7 kg) is the value sweet spot — sub-23 kg carbon enduro at this price is genuinely competitive. Trim 1 at £7,999 (23.4 kg) and trim 0 at £9,999 (22.3 kg) move up the suspension and drivetrain ladder. Expect RockShox or Fox suspension at 180 mm front, four-piston brakes and SRAM or Shimano 12-speed drivetrains. Giant's dealer network is one of the deepest in the industry, which matters for warranty and after-sales.
Caveats and known gripes.
  • SyncDrive Pro 3 is Giant's in-house motor with limited third-party tuning ecosystem compared to Bosch (eBike Flow), DJI (Avinox app) or Shimano (E-TUBE PROJECT). You're locked into Giant's RideControl app for diagnostics and updates.
  • 560 Wh battery is small by 2026 standards. Most rivals run 720 to 900 Wh, which translates to meaningful range advantages on long rides.
  • 85 Nm torque is below the headline category leaders. Buyers chasing the highest torque figures will look elsewhere.
  • Community presence on the forum is limited for the 2026 model — no curated owner quotes yet, so real-world reliability data will accumulate through 2026 and beyond.
Verdict. The Reign Advanced E+ 2026 is one of the most thoughtful carbon enduro eMTB launches of the year, with Giant's deep dealer network, refined Maestro suspension and the most generous geometry adjustability in the segment. It suits riders who value Giant's after-sales support, who don't need headline-grabbing motor torque, and who appreciate the 26-position size/configuration matrix for getting a properly tailored fit. Look elsewhere if you want maximum motor torque (DJI Avinox M2S, Bosch CX Gen 5), the largest available battery, or aftermarket motor tuning ecosystems. Production status: current, three trims, available now.
Bike geometry diagram
SMLXLLG HighLG LowLG MidMD HighMD LowMD MidSM HighSM LowSM MidXL HighXL LowXL Mid
Reach430 mm460 mm480 mm510 mm470 mm476 mm466 mm450 mm456 mm446 mm435 mm426 mm430 mm501 mm505 mm497 mm
Stack645 mm654 mm667 mm680 mm645 mm669 mm648 mm636 mm656 mm639 mm642 mm647 mm645 mm650 mm683 mm653 mm
Chainstay450 mm450 mm450 mm450 mm442 mm450 mm443 mm442 mm450 mm443 mm450 mm450 mm450 mm442 mm450 mm443 mm
Headtube Angle63.5°63.5°63.5°63.5°63°63.1°62.6°63°63.1°62.6°63.9°63.1°63.5°63°63.1°62.6°
Seattube Angle (eff)77.5°77.5°77.5°77.5°76.8°77.1°76.4°77.8°77.1°77.4°77.9°77.1°77.5°76.8°77.1°76.4°
BB Drop15 mm10 mm20 mm15 mm10 mm20 mm10 mm10 mm5 mm15 mm10 mm21 mm
Wheelbase1227 mm1261 mm1289 mm1324 mm1274 mm1287 mm1275 mm1250 mm1261 mm1251 mm1227 mm1226 mm1226 mm1307 mm1323 mm1308 mm
Headtube105 mm120 mm105 mm105 mm105 mm105 mm95 mm95 mm95 mm120 mm135 mm120 mm
Standover755 mm750 mm739 mm734 mm749 mm744 mm
Front Centre777 mm811 mm839 mm874 mm832 mm837 mm832 mm808 mm811 mm808 mm777 mm776 mm776 mm865 mm873 mm865 mm
Trims · 3
£7,499
£9,999
Reign Advanced E+ 0
£9,999
MotorGiant SyncDrive Pro · 85 Nm · all trims
BatteryGiant EnergyPak Smart 560 · 560 Wh · all trims
Travel F/R180/170 mm · all trims
FrameCarbon (Advanced-Grade composite) · all trims
ForkFox 38 Performance Elite, 29", 180mm travel, Grip X2 damper, 44mm offsetFox 38 Factory, 29", 180mm travel, Grip X2 damper, 44mm offsetFox 38 Factory, 29", 180mm travel, Grip X2 damper, 44mm offset
ShockFox Float X Performance, EVOL Large Volume sleeve, 205x65mm Trunnion mountFox Float X2 Factory, EVOL Large Volume sleeve, 205x65mm Trunnion mountFox Float X2 Factory, EVOL Large Volume sleeve, 205x65mm Trunnion mount
StemGiant Contact SL 35Giant Contact SLR Trail, integrated carbon 1-piece handlebarGiant Contact SLR Trail, integrated carbon 1-piece handlebar
HandlebarGiant Contact SL TR35, 35x800mm, 35mm rizeGiant Contact SLR Trail, integrated carbon 1-piece handlebar 800mmGiant Contact SLR Trail, integrated carbon 1-piece handlebar 800mm
GripsGiant Tactal Pro-E · all trims
SaddleGiant Romero, NeutralGiant Romero SL, NeutralGiant Romero SL, Neutral
SeatpostGiant Contact Switch adjustable dropper, 30.9mm (M: 140~170)Fox Transfer Factory, 30.9mm, MMX remoteFox Transfer Factory, 30.9mm, MMX remote
BrakesTRP DH-R EVO, hydraulic disc, E2.3 caliper, 4-piston, 220mm [F/R]SRAM Maven Ultimate, 4-piston, 200mm CenterLine [F/R]SRAM Maven Ultimate, 4-piston, 200mm CenterLine [F/R]
Rear derailleurSRAM 90 Eagle TransmissionSRAM XX Eagle Transmission AXSSRAM XX Eagle Transmission AXS
CrankSRAM Eagle Transmission 36T chainring Praxis e-HD forged crankarm setSRAM XX Eagle Transmission Direct Mount E-MTB Chainring 36TSRAM XX Eagle Transmission Direct Mount E-MTB Chainring 36T
ShiftersSRAM Eagle 90 Transmission Single ClickSRAM AXS POD Rocker PaddleSRAM AXS POD Rocker Paddle
CassetteSRAM Eagle Transmission, 10-52T, 12-speedSRAM XO Eagle Transmission, 10-52T, 12-speedSRAM XO Eagle Transmission, 10-52T, 12-speed
ChainSRAM 70 Eagle Transmission Flattop Powerlink 12-speedSRAM XO Eagle Transmission Flattop Powerlock 12-speedSRAM XO Eagle Transmission Flattop Powerlock 12-speed
DrivetrainSRAM 90 Eagle Transmission; SRAM Eagle Transmission 36T chainring Praxis e-HD forged crankarm set; SRAM Eagle 90 Transmission Single Click; SRAM Eagle Transmission, 10-52T, 12-speed; SRAM 70 Eagle Transmission Flattop Powerlink 12-speedSRAM XX Eagle Transmission AXS; SRAM XX Eagle Transmission Direct Mount E-MTB Chainring 36T; SRAM AXS POD Rocker Paddle; SRAM XO Eagle Transmission, 10-52T, 12-speed; SRAM XO Eagle Transmission Flattop Powerlock 12-speedSRAM XX Eagle Transmission AXS; SRAM XX Eagle Transmission Direct Mount E-MTB Chainring 36T; SRAM AXS POD Rocker Paddle; SRAM XO Eagle Transmission, 10-52T, 12-speed; SRAM XO Eagle Transmission Flattop Powerlock 12-speed
WheelsGiant e-TRA aluminium wheelset (MX: 29" front / 27.5" rear), hookless, 30mm inner width, Giant e-TRA E-Drive 260Nm 6-Pawl 72T hubsGiant TRX Carbon wheelset (MX: 29" front / 27.5" rear), 30mm inner width, Giant TRX E-Drive 260Nm 6-Pawl 72T hubsGiant TRX Carbon wheelset (MX: 29" front / 27.5" rear), 30mm inner width, Giant TRX E-Drive 260Nm 6-Pawl 72T hubs
TyresFront: Maxxis Assagai 29x2.5" foldable, tubeless, EXO+ 3C MaxxGrip; Rear: Maxxis MINION DHR II 27.5x2.4" WT foldable, Tubeless, DoubleDown · all trims
Weight23.4 kg22.3 kg22.7 kg
Price£7,499£9,999£9,999
Spot a mistake?
