Bike Finder · GasGas
GasGas MXC
GasGas
MXC 2026
CurrentAll-MountainAgeing · 3.7/10iFreshness 3.7/10
Motor
SRAM Eagle Powertrain · 90Nm · 680W
Battery
SRAM Eagle Powertrain 630Wh
Travel F/R
160/140mm
Wheels
MX (29F / 27.5R)
Frame
Full carbon
Weight
23.3 kg
Price
From £6,499
View the GasGas MXC on GasGas’s site
GasGas MXC 2026
From £6,499
Bike geometry diagram
L/XLM/LS/M
Reach495 mm470 mm445 mm
Stack671 mm658 mm644 mm
Seattube470 mm440 mm400 mm
Chainstay450 mm445 mm442 mm
Headtube Angle64.5°64.5°64.5°
Seattube Angle (eff)74°74°74°
BB Drop31.5 mm31.5 mm31.5 mm
Wheelbase1299 mm1262 mm1228 mm
Front Centre849 mm*817 mm*786 mm*
Trims · 3
MXC 4
£6,499
MXC 5
£7,999
MXC 6
£8,999
MotorSRAM Eagle Powertrain · 90 Nm · all trims
BatterySRAM Eagle Powertrain 630Wh · 630 Wh · all trims
Travel F/R160/140 mm · all trims
FrameCarbon · all trims
ForkRockShox Lyrik Select+ DebonAir+, 160mmDVO Onyx D1CV SL (powered by WP), 160mmDVO Onyx D1CV OTT (powered by WP), 160mm
ShockRockShox Deluxe Select+ Air, 205x60mmDVO Topaz Air CV, 205x60mmDVO Topaz Air CV, 205x60mm
HeadsetAcros AZX-579 ZS56/ZS56 · all trims
StemGASGAS 35, 0 °, AheadGASGAS 35, 0 °, AheadNEWMEN Evolution 318.4, Ahead
HandlebarGASGAS Riser 35 mm, 780 mm, Sweep: 9 °, Rise: 20 mmGASGAS Riser 35 mm, 780 mm, Sweep: 9 °, Rise: 20 mmNEWMEN Advanced 318.25, 800 mm, Rise: 25 mm
GripsGASGAS MTB, Lock-on grips · all trims
SaddleSelle Royal Terra Ridon X5
SeatpostGASGAS Pro, 34.9 mm, Dropper postGASGAS Pro, 34.9 mm, Dropper postRockShox Reverb AXS
BrakesSRAM DB8, 4-piston hydraulic disc, 220/200mmSRAM G2 RS, 4-piston hydraulic disc, 220/200mmSRAM Code RSC, 4-piston hydraulic disc, 220/200mm
Rear derailleurSRAM GX Eagle, 12-speedSRAM GX Eagle Transmission AXS, 12-speedSRAM X0 Eagle Transmission AXS, 12-speed
CrankSRAM GX Eagle E-MTBSRAM GX Eagle E-MTBSRAM X0 Eagle E-MTB
ShiftersSRAM SX Eagle, Single ClickSRAM AXS Pod Ultimate ControllerSRAM AXS Pod Ultimate Controller
CassetteSRAM PG-1210, 11-50 TSRAM XS-1275, 10-52 TSRAM XS-1295, 10-52 T
ChainSRAM SX EagleSRAM GX Eagle Transmission FlattopSRAM X0 Eagle Transmission Flattop
DrivetrainSRAM GX Eagle, 12-speed; SRAM GX Eagle E-MTB; SRAM SX Eagle, Single Click; SRAM PG-1210, 11-50 T; SRAM SX EagleSRAM GX Eagle Transmission AXS, 12-speed; SRAM GX Eagle E-MTB; SRAM AXS Pod Ultimate Controller; SRAM XS-1275, 10-52 T; SRAM GX Eagle Transmission FlattopSRAM X0 Eagle Transmission AXS, 12-speed; SRAM X0 Eagle E-MTB; SRAM AXS Pod Ultimate Controller; SRAM XS-1295, 10-52 T; SRAM X0 Eagle Transmission Flattop
WheelsMach 1 TRUCKY 30 rims, GASGAS DA210F / DA210R hubsMach 1 TRUCKY 30 rims, GASGAS DA210F / DA210R hubsNEWMEN Evolution SL E.G. 30, tubeless ready (front 15x110 mm, rear 12x148 mm)
TyresMaxxis Assegai 29x2.5 front / Maxxis Minion DHR II 27.5x2.4 rear · all trims
Weight23.3 kg24.3 kg
Price£6,499£7,999£8,999
Rides similarly
Spot a mistake?
