Bike Finder · GasGas
GasGas G Trail
GasGas
G Trail 2025
CurrentTrailMature · 5.5/10iFreshness 5.5/10
Motor
Yamaha PW-ST
Battery
Simplo 630Wh
Travel F/R
150/150mm
Wheels
29F / 29R
Frame
Aluminium / Carbon front, aluminium rear
Weight
24.5 kg
Price
From £3,999
View the GasGas G Trail on GasGas’s site
GasGas G Trail 2025
From £3,999
Bike geometry diagram
MLXL
Reach462 mm486 mm508 mm
Stack642 mm647 mm656 mm
Chainstay475 mm475 mm475 mm
Headtube Angle65.5°65.5°65.5°
Seattube Angle (eff)74°74°74°
BB Drop28 mm28 mm28 mm
Wheelbase1264 mm1290 mm1317 mm
Front Centre789 mm*815 mm*842 mm*
Trims · 2
G Trail 2.0
£3,999
G Trail 3.0
£4,999
MotorYamaha PW-ST · 70 Nm · all trims
BatterySimplo 630Wh · 630 Wh · all trims
Travel F/R150/150 mm · all trims
Frame6061 alloyCarbon front triangle / 6061 alloy rear triangle
ForkRockShox Revelation RC, DebonAir, 150mmFOX FLOAT 36 Factory, FIT4, 150mm
ShockRockShox Deluxe Select+, 230x65mmFOX FLOAT DPS Factory, Kashima
HeadsetGASGAS, ZS44 upper / ZS56 lower · all trims
StemGASGAS, 35mm, 0 rise, 31.8mm clampGASGAS, 35mm, 0 rise, 35mm clamp
HandlebarGASGAS, 780mm width, 31.8mm clampGASGAS, 780mm width, 35mm clamp
GripsGASGAS MTB, lock-on · all trims
SaddleGASGAS MTB · all trims
SeatpostGASGAS Pro dropper, 31.6mmGASGAS Pro dropper
BrakesSRAM DB8, 4-piston (200/180mm)SRAM G2 R, 4-piston (200/180mm)
Rear derailleurSRAM SX Eagle, 12-speedSRAM GX Eagle, 12-speed
CrankGASGAS EC40, forged aluminum, 165mm · all trims
ShiftersSRAM SX Eagle, 12-speed, Single Click · all trims
CassetteSRAM SX Eagle PG-1210, 12-speed, 11-50T · all trims
ChainSRAM SX Eagle, 12-speed · all trims
DrivetrainSRAM SX Eagle, 12-speed; GASGAS EC40, forged aluminum, 165mm; SRAM SX Eagle, 12-speed, Single Click; SRAM SX Eagle PG-1210, 12-speed, 11-50T; SRAM SX Eagle, 12-speedSRAM GX Eagle, 12-speed; GASGAS EC40, forged aluminum, 165mm; SRAM SX Eagle, 12-speed, Single Click; SRAM SX Eagle PG-1210, 12-speed, 11-50T; SRAM SX Eagle, 12-speed
WheelsMach 1 TRUCKY 30 alloy rims (tubeless ready) with GASGAS DA210F front / DA210R rear hubs · all trims
TyresSchwalbe Nobby Nic, Evo, TR, 29 x 2.4 · all trims
Weight25.5 kg24.5 kg
Price£3,999£4,999
Spot a mistake?
