Bike Finder · Fantic
Fantic XXF 2.0
Fantic
XXF 2.0 2023
DiscontinuedFull Power · GravityLegacy · 0.2/10iFreshness 0.2/10
Travel F/R
200/190mm
Wheels
MX (29F / 27.5R)
Frame
Aluminium
Weight
Price
From £6,599
View the Fantic XXF 2.0 on Fantic’s site
Fantic XXF 2.0 2023
From £6,599
EMTB Forums verdict
The Fantic XXF 2.0 was the Italian brand's downhill e-MTB flagship in the Integra range, and it makes no apology for it. A dual-crown 200mm fork up front, 190mm out back through Fantic's high-pivot Full Floater linkage, and a mixed 29in front / 27.5in rear wheel setup mark this out as a gravity machine rather than a do-everything trail bike.
Power comes from the Brose Drive S Mag (90Nm) motor fed by an integrated 720Wh Fantic Integra battery, so there is plenty of capacity for repeat laps. The aluminium frame uses a Fantic Flip Chip to switch between two rear-wheel positions and geometries, and the numbers are aggressively slack at 64 degrees with a long 1226 to 1281mm wheelbase across S to L.
Two builds were offered. The Factory ran Ohlins DH 38 fork and TTX 22M coil shock with a SRAM GX drivetrain, while the Race used a RockShox BOXXER Select fork and Super Deluxe Coil shock with Magura MT7 brakes and a SRAM NX/SX mix. Both shared the same frame, motor, battery and 220/203mm Braking rotors.
This is a discontinued 2023 model and the XXF 2.0 has since left the Fantic line-up, so it is now a used-market or clearance proposition. UK RRPs were 8,199 pounds for the Factory and 6,599 pounds for the Race.
Geometry read
Size
Descending
83
Slack 64.5° head angle, 190mm travel and a long 1281mm wheelbase — composed in the chunk, confident when it gets steep, and stable through fast corners.
Playfulness
18
More planted than poppy — better on steep terrain than tight, fiddly singletrack.
Size balance
97
Rear-long with a planted front in L (FC:RC 1.79) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
65
Climbs well — a 72° seat keeps the front planted. 560W of peak power and 90Nm of torque — a strong full-power motor.
Best suited toFast, steep, rough tracks — and riders who want maximum composure.
Rewards commitment; it should feel calmer as the speed rises.
Watch out forNot a flickable, playful bike — built to plough, not pop.
Brilliant on fast, rough, steep terrain; less fun on tight, mellow trails.
How it stacks up vs other Full Power · Gravity bikes (from 117 bikes in the database)
Battery720 Whabout average capacity
Motor torque90 Nm13 Nm below average
Value for money52/100from £6,599 · most Brose Drive S Mag bikes ~£6,699
⚙️ Adjustable geometry: this frame has a high/low setting — low drops the BB and slackens the head angle for more descending stability; high lifts the BB and steepens slightly for clearance and a perkier, more playful feel.
💬 Forum discussion
New Fantic Fat Sport Integra - Info Updated Regularly
43 replies · 7.8k views · last reply 12 months ago
Join the discussion →
“Been riding/feeling out the bike the last couple of days on my local bike path route (12 miles roundtrip). No real snow currently on the Denver Front Range and not wanting to travel up I-70. Am really impressed with the build quality as…”
— JB01245 · ♥ 4 · most-liked post
Bike geometry diagram
SML
Reach416 mm445.5 mm471.5 mm
Stack621 mm630 mm642 mm
Seattube390 mm430 mm470 mm
Chainstay458.5 mm458.5 mm458.5 mm
Headtube Angle64°64°64.5°
Seattube Angle (eff)72°72°72°
Wheelbase1226 mm1256 mm1281 mm
Headtube105 mm110 mm120 mm
BB Height370 mm370 mm370 mm
Standover791 mm807 mm810 mm
Front Centre767.5 mm*797.5 mm*822.5 mm*
FC:RC1.671.741.79
Trims · 2
Race
£6,599
Factory
£8,199
MotorBrose Drive S Mag · 90 Nm · all trims
BatteryFantic Integra 720Wh · 720 Wh · all trims
Travel F/R200/190 mm · all trims
FrameAluminium · all trims
ForkRockShox BOXXER Select e-bike 29" 200mmOhlins DH 38 e-bike 29" 200mm
ShockRockShox Super Deluxe Coil Select+ T205x65Ohlins TTX 22M T205x65
StemFSA DIRETTO 45mm-35Renthal INTEGRA 45mm-35
HandlebarFSA Gradient 800mm-35 RISE25Renthal FATBAR V2 800mm-35 RISE30
SaddleSelle Italia Novus Boost Model X Comfort SuperflowSelle Italia Novus Boost X Cross Superflow
SeatpostSWITCH SW 30.9mm, S-M 100mm / L 125mmRockShox Reverb 30.9mm, S-M 100mm / L 125mm
BrakesMagura MT7 4-piston disc brakes (front and rear); rotors Braking S3 Battfly 220mm front / 203mm rear, 6-holeBraking IN.CA.S disc brakes (front and rear); rotors Braking S3 Battfly 220mm front / 203mm rear, 6-hole
Rear derailleurSram NX Eagle 12VSram GX Eagle 12V
CrankFSA CK-320/ISIS 155mm, Sram 34t Steel Eagle chainring · all trims
ShiftersSram NX E-clickSram GX E-click
CassetteSram SX Eagle 12V, 11-50Sunrace SilverRed 12V, 11-51
ChainSram NX Eagle 12V · all trims
DrivetrainSram NX Eagle 12V; FSA CK-320/ISIS 155mm, Sram 34t Steel Eagle chainring; Sram NX E-click; Sram SX Eagle 12V, 11-50; Sram NX Eagle 12VSram GX Eagle 12V; FSA CK-320/ISIS 155mm, Sram 34t Steel Eagle chainring; Sram GX E-click; Sunrace SilverRed 12V, 11-51; Sram NX Eagle 12V
WheelsMavic E-XM wheels · all trims
TyresVittoria E-MAZZA 29"x2.6 (front) / Vittoria E-MARTELLO 27.5"x2.8 (rear) · all trims
Price£6,599£8,199
Rides similarly
Spot a mistake?
