Bike Finder · Fantic
Fantic XXF 2.0
Fantic
XXF 2.0 2022
DiscontinuedFull Power · GravityLegacy · 0.2/10iFreshness 0.2/10
Motor-assisted downhill rig for uplift-free runs on the steepest tracks
Travel F/R
200/200mm
Wheels
MX (29F / 27.5R)
Frame
Aluminium
Weight
Price
From £6,699
View the Fantic XXF 2.0 on Fantic’s site
Fantic XXF 2.0 2022
From £6,699
EMTB Forums verdict
The Fantic XXF 2.0 was the Italian brand's no-compromise downhill e-MTB, since discontinued. Built around an aluminium frame with Fantic's Full Floater rocker-link suspension, it ran a full 200mm of travel front and rear on a mixed-wheel platform (29in front, 27.5in rear), with Vittoria E-Mazza and E-Martello rubber to match.
Power came from a Brose S-MAG drive unit rated at 90 Nm, fed by a 720Wh Fantic Integra battery, so it carried plenty of assistance up to the top of the trail before pointing back down. Two trims were offered: the Factory with Ohlins DH38 fork and TTX 22M coil shock and a SRAM GX drivetrain, and the more affordable Race with a RockShox BOXXER Select fork, Super Deluxe Coil shock, Magura MT7 brakes and a SRAM NX/SX build.
Both trims used the same downhill-race geometry, with a slack 64 degree head angle, a 72 degree seat angle and a long 1226 to 1281mm wheelbase across the three sizes (S to L). UK pricing was around 8,199 pounds for the Factory and 6,699 pounds for the Race. As a discontinued model, availability is now limited to remaining stock and the used market.
Geometry read
Size
Descending
84
Slack 64.5° head angle, 200mm travel and a long 1281mm wheelbase — composed in the chunk, confident when it gets steep, and stable through fast corners.
Playfulness
20
More planted than poppy — better on steep terrain than tight, fiddly singletrack.
Size balance
97
Rear-long with a planted front in L (FC:RC 1.79) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
65
Climbs well — a 72° seat keeps the front planted. 560W of peak power and 90Nm of torque — a strong full-power motor.
Best suited toFast, steep, rough tracks — and riders who want maximum composure.
Rewards commitment; it should feel calmer as the speed rises.
Watch out forNot a flickable, playful bike — built to plough, not pop.
Brilliant on fast, rough, steep terrain; less fun on tight, mellow trails.
How it stacks up vs other Full Power · Gravity bikes (from 135 bikes in the database)
Battery720 Whabout average capacity
Motor torque90 Nm11 Nm below average
Value for money50/100from £6,699 · most Brose Drive S Mag bikes ~£6,699
💬 Forum discussion
New Fantic Fat Sport Integra - Info Updated Regularly
43 replies · 7.9k views · last reply 12 months ago
Join the discussion →
“Been riding/feeling out the bike the last couple of days on my local bike path route (12 miles roundtrip). No real snow currently on the Denver Front Range and not wanting to travel up I-70. Am really impressed with the build quality as…”
— JB01245 · ♥ 4 · most-liked post
Bike geometry diagram
SML
Reach416 mm445.5 mm471.5 mm
Stack588.5 mm619 mm649 mm
Seattube390 mm430 mm470 mm
Chainstay458.5 mm458.5 mm458.5 mm
Headtube Angle64°64°64.5°
Seattube Angle (eff)72°72°72°
Wheelbase1226 mm1256 mm1281 mm
Headtube105 mm110 mm120 mm
BB Height368 mm370 mm370 mm
Front Centre767.5 mm*797.5 mm*822.5 mm*
FC:RC1.671.741.79
Trims · 2
Race
£6,699
Factory
£8,199
MotorBrose Drive S Mag · 90 Nm · all trims
BatteryFantic Integra 720Wh · 720 Wh · all trims
Travel F/R200/200 mm · all trims
FrameAluminium · all trims
ForkRockShox BOXXER Select e-bike - 29" 200mmOhlins DH 38 e-bike - 29" 200mm
ShockRockShox SuperDeluxe Coil Select+ T205x65Ohlins TTX 22M T205x65
StemFSA DIRETTO 40mm-35Renthal INTEGRA 45mm-35
HandlebarFSA GRID 800mm-35 RISE15Renthal FATBAR V2 800mm-35 RISE30
SaddleSella Italia Novus Boost EVO · all trims
SeatpostSWITCH SW Ø 30.9, S-M(100mm) / L(125mm)Rockshox Reverb Ø 30.9, S-M(100mm) / L(125mm)
BrakesMagura MT7 4 Piston disc brake (front and rear)Braking IN.CA.S 4-piston disc brake (front and rear), Braking S3 Battfly rotors 220mm front / 203mm rear, 6-bolt
Rear derailleurSram NX Eagle 12VSram GX Eagle 12V
CrankFSA CK-320/ISIS - 155mm, Sram 34t Steel Eagle chainring · all trims
ShiftersSram NX E-clickSram GX E-click
CassetteSram SX Eagle 12V, 11-50Sunrace SilverRed 12V, 11-51
ChainSram NX Eagle 12V · all trims
DrivetrainSram NX Eagle 12V; FSA CK-320/ISIS - 155mm, Sram 34t Steel Eagle chainring; Sram NX E-click; Sram SX Eagle 12V, 11-50; Sram NX Eagle 12VSram GX Eagle 12V; FSA CK-320/ISIS - 155mm, Sram 34t Steel Eagle chainring; Sram GX E-click; Sunrace SilverRed 12V, 11-51; Sram NX Eagle 12V
WheelsMavic E-XM · all trims
TyresVittoria E-MAZZA 29"x2.6 (front) / Vittoria E-MARTELLO 27.5"x2.8 (rear) · all trims
Price£6,699£8,199
Rides similarly
Spot a mistake?
