Bike Finder · Fantic
Fantic XTF 1.6 Carbon
Fantic
XTF 1.6 Carbon 2024
DiscontinuedFull Power · TrailLegacy · 0.9/10iFreshness 0.9/10
Motor
Brose Drive S Mag · 90Nm · 560W
Battery
Fantic Integra 720 · 720Wh
Travel F/R
160/150mm
Wheels
29F / 29R
Frame
Full carbon
Weight
19.9 kg
Price
From £6,499
View the Fantic XTF 1.6 Carbon on Fantic’s site
Fantic XTF 1.6 Carbon 2024
From £6,499
EMTB Forums verdict
The Fantic XTF 1.6 Carbon was the brand's flagship carbon trail e-MTB, built around a 29in carbon frame with 160mm of fork travel, the Full Floater rocker-link rear end and Fantic's patented Flip Chip that swaps the rear wheel between two positions to suit 2.2in or 2.4in tyres. Power comes from the lightweight Brose S-Mag motor (90 Nm) fed by a 720Wh Fantic Integra battery, a combination that helped the range-topping Factory hit a claimed 19.9kg.
Three trims shared the same frame and geometry, so the choice is purely about kit. The Factory at £10,999 is the showpiece, with a RockShox Lyrik Ultimate fork, Deluxe Ultimate shock, SRAM XX1 AXS wireless shifting, FSA carbon wheels and a Reverb AXS dropper. The Race at £7,999 keeps a carbon cockpit and wheels but steps down to GX AXS and a SRAM G2 RS brake. The Sport at £6,499 is the value entry, using alloy Rodi rims, mechanical SRAM NX/GX shifting and a fixed seatpost, making the Race the sweet spot for riders who want wireless shifting without the Factory's price.
Geometry is moderate by modern standards: a 66 to 67 degree head angle, 73 degree seat angle and a consistent 456mm chainstay across all four sizes, paired with reach figures from 419mm (S) to 488mm (XL). That points to a balanced, manageable trail bike rather than an out-and-out enduro sled.
This 2024 model is now discontinued. Fantic has since restructured its trail line under the Ridge and Sierra names using Bosch Performance Line CX Gen 5 motors, so the Brose-powered XTF 1.6 Carbon represents the end of that platform's lineage.
Geometry read
Size
Descending
52
A solid all-round descender (66.5° head angle, 150mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
48
Size balance
85
Rear-long with a planted front in L (FC:RC 1.71) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
74
Brose Drive S Mag and a steep 73° seat angle keep the weight planted over the front — a proper winch. 560W of peak power and 90Nm of torque — a strong full-power motor.
How it stacks up vs other Full Power · Trail bikes (from 227 bikes in the database)
Weight19.9 kg3.1 kg lighter than average
Battery720 Whabout average capacity
Motor torque90 Nm8 Nm below average
Value for money50/100from £6,499 · most Brose Drive S Mag bikes ~£6,499
⚙️ Adjustable geometry: this frame has a high/low setting — low drops the BB and slackens the head angle for more descending stability; high lifts the BB and steepens slightly for clearance and a perkier, more playful feel.
Bike geometry diagram
SMLXL
Reach419 mm438 mm466 mm488 mm
Stack608 mm615 mm629 mm646 mm
Seattube390 mm430 mm469 mm510 mm
Chainstay456 mm456 mm456 mm456 mm
Headtube Angle66°66.5°66.5°67°
Seattube Angle (eff)73°73°73°73°
Wheelbase1188 mm1204 mm1238 mm1260 mm
Headtube100 mm105 mm120 mm135 mm
BB Height363 mm363 mm363 mm363 mm
Front Centre732 mm*748 mm*782 mm*804 mm*
FC:RC1.611.641.711.76
Trims · 3
Sport
£6,499
Race
£7,999
Factory
£10,999
MotorBrose Drive S Mag · 90 Nm · all trims
BatteryFantic Integra 720 · 720 Wh · all trims
Travel F/R160/150 mm · all trims
FrameCarbon · all trims
ForkRockShox Lyrik Select 160mm, AirRockShox Lirik Select 160mmRockShox Lyrik Ultimate 160mm, Air
ShockRockShox Deluxe Select+RockShox Deluxe Select+RockShox Deluxe Ultimate
StemFSA 60mm Ø31,8 Rise +6°FSA NS ICR 10°AO 70mm Ø31,8nd/na
HandlebarFSA 760mm Ø31,8 Rise 15mm Sweep 6°FANTIC RACING Carbon Ø31,8 Rise 25, 760mmFANTIC RACING INTEGRATED FLAT -17°, 780mm
SaddleSelle Italia X BOW SuperflowSelle Italia Novus Boost X-CROSS SuperflowSelle Italia SLR Boost Superflow
SeatpostSwitch SW Ø30.9 (Rigid)Switch SW Ø30.9 (Rigid)RockShox Reverb AXS Ø30.9 (Dropper)
BrakesSRAM G2 RS 4 Piston disc brakeSRAM G2 RS 4 Piston disc brakeMagura MT Trail Sport 4 Piston disc brake
Rear derailleurSRAM GX EagleSRAM GX AXS EagleSRAM XX1 AXS Eagle
CrankSRAM 34t · all trims
ShiftersSRAM NXSRAM GX AXSSRAM XX1 AXS
CassetteSRAM SX, 12V, 11-50SunRace SilverRed, 12V, 11-51SRAM X-Glide Rainbow, 12V, 10-52
ChainSRAM SXSRAM SXSRAM
DrivetrainSRAM GX Eagle; SRAM 34t; SRAM NX; SRAM SX, 12V, 11-50; SRAM SXSRAM GX AXS Eagle; SRAM 34t; SRAM GX AXS; SunRace SilverRed, 12V, 11-51; SRAM SXSRAM XX1 AXS Eagle; SRAM 34t; SRAM XX1 AXS; SRAM X-Glide Rainbow, 12V, 10-52; SRAM
WheelsRodi READY27 - 29"FSA i29 Carbon 29"FSA KFX Carbon 29"
TyresPirelli SCORPION ProWall Trail -R- 29"x 2.4 · all trims
Weight19.9 kg
Price£6,499£7,999£10,999
Rides similarly
Spot a mistake?
