Bike Finder · Fantic
Fantic XTF 1.6 Carbon Factory
Fantic
XTF 1.6 Carbon Factory 2025
CurrentTrail eMTBAgeing · 3.5/10iFreshness 3.5/10
Brose S MAG ultralight full-carbon trail eMTB
Motor
Brose Drive S Mag · 90Nm · 565W
Battery
Fantic Integrated 720 · 720Wh
Travel F/R
160/160mm
Wheels
29F/29R (flip-chip 27.5R compatible)
Frame
Carbon front, aluminium rear
Weight
19.9 kg
Price
£11,041
View the Fantic XTF 1.6 Carbon Factory on Fantic’s site
Fantic XTF 1.6 Carbon Factory 2025
From £11,041
EMTB Forums verdict
The Fantic XTF 1.6 Carbon Factory 2025 is an Italian flagship carbon trail eMTB built around Brose's Drive S Mag motor and an integrated 720 Wh battery. Headline numbers: 160 mm of travel front and rear, 90 Nm torque, 565 W peak, a claimed 19.9 kg system weight, a 66 to 67 degree adjustable head angle and a 419 to 488 mm reach range across four sizes. £10,999 for the single Factory trim. Community verdict: a niche, premium Italian platform that pairs Brose's silent, natural assist feel with a serious carbon frame for buyers willing to pay top-of-the-class money.
Drive system and range. The Brose Drive S Mag is one of the quietest motors in eMTB, using a magnesium housing and Brose's signature belt-driven internal architecture for a near-silent, low-cadence-friendly assist. Peak power sits at 565 W and torque at 90 Nm, which compares directly with Bosch CX Gen 4 on output but with a meaningfully different character (smoother off-the-line, less aggressive at the top). The integrated, non-removable 720 Wh pack is on the larger side of the trail eMTB market and supports 60 to 90 km mixed-terrain rides depending on assist mode and rider weight. Brose firmware updates roll through Specialized's MasterMind ecosystem on platforms that share the motor, but the Fantic implementation typically requires dealer-side updates rather than rider-app self-service.
Geometry and handling. The XTF 1.6 uses size-specific head angles, which is an unusual feature: 66 degrees on size S, 66.5 degrees on M and L, and 67 degrees on XL. That means the bike steepens slightly as it grows, which contradicts the more common 'one head angle across all sizes' approach but reflects Fantic's attempt to keep handling consistent across rider heights. Reach grows from 419 mm in S to 488 mm in XL, a 69 mm spread that suits both petite and tall riders. The 456 mm chainstay is identical across sizes, on the longer side of the trail-eMTB market, which favours stable climbing and high-speed composure over agile direction changes. Wheelbases run 1188 to 1260 mm.
Build and value. One trim, £10,999 Factory. At this price step buyers expect top-end suspension, drivetrain and brakes, with high-end finishes throughout. Fantic delivers a carbon Full Floater chassis (unique within the eMTB market, where Horst Link, 4-bar and split pivot dominate), Brose's premium Drive S Mag motor with magnesium housing, and an integrated 720 Wh battery for genuine all-day range. The standout strength is the chassis weight: a claimed 19.9 kg on a 160/160 mm full-power eMTB is properly impressive, undercutting most aluminium trail-eMTB rivals by 4 to 6 kg. The questionable note is the single-trim ladder: at £10,999 there is no budget entry point into the Fantic XTF Carbon line.
Caveats and known gripes. The integrated, non-removable battery is the biggest compromise: owners who tour, share a charger, or live in flats without easy charging need to plan around this. Fantic UK dealer reach is thinner than the German or US brands, so warranty and motor service can mean longer wait times outside the Italian and Iberian markets. The Brose Drive S Mag is a known-strong motor but service requires authorised Brose centres, which are less common than Bosch or Shimano. And at £10,999 the Factory trim sits at the very top of the trail eMTB price band, with buyers needing to weigh that against equivalent flagship trims from Specialized, Pivot and Yeti.
Verdict. The XTF 1.6 Carbon Factory 2025 suits the buyer who wants an Italian-designed flagship trail eMTB with one of the quietest motors in the market, a properly light 19.9 kg chassis and adjustable head-angle geometry, and who can live with an integrated battery and direct-dealer service model. Riders wanting removable batteries, more accessible pricing or stronger dealer support should look at the Levo Gen 4, the Cannondale Moterra Neo or the Amflow PR Carbon. Production status: current.
Bike geometry diagram
SMLXL
Reach419 mm438 mm466 mm488 mm
Stack608 mm615 mm629 mm645 mm
Chainstay456 mm456 mm456 mm456 mm
Headtube Angle66°66.5°66.5°67°
Seattube Angle (eff)73°73°73°73°
Wheelbase1188 mm1204 mm1238 mm1260 mm
Front Centre732 mm748 mm782 mm804 mm
Trims · 1
Factory
£11,041
MotorBrose Drive S Mag · 90 Nm
BatteryFantic Integrated 720 · 720 Wh
Travel F/R160/160 mm
FrameCarbon front + Aluminium rear
ForkRockShox Lyrik Ultimate 160mm
ShockRockShox Deluxe Ultimate 205x60mm
HeadsetFSA 1-1/8" - 1.5"
StemFSA, 65 mm, -12°
HandlebarFSA KFX SIC, width 780mm
SaddleSelle Italia SLR Boost Superflow
SeatpostRockShox Reverb AXS
BrakesMagura MT Trail Carbon 4-piston, 203 mm front / 180 mm rear rotors
Rear derailleurSRAM XX1 AXS Eagle
CrankFSA CK-8685-1 170mm
ShiftersSRAM AXS Eagle
CassetteSRAM Eagle 12s Rainbow 10-52
ChainSRAM XX1 Eagle 12s Rainbow
DrivetrainSRAM XX1 AXS Eagle (12-speed)
WheelsFSA KFX Carbon 29"
TyresPirelli Scorpion ProWall Trail M 29x2.4 front / Scorpion ProWall Trail R 29x2.4 rear
Weight19.9 kg
Price£11,041
Spot a mistake?
