A solid all-round descender (66.5° head angle, 150mm) — capable in the rough and steep without being an all-out bruiser.
XTF 1.5 2023
The 2023 Fantic XTF 1.5 was the entry point into the Italian brand's full-suspension trail line, built around a hydroformed aluminium frame with 150mm of travel front and rear via Fantic's full-float linkage-driven single-pivot rear end. Power came from a Fantic-branded Brose mid-drive rated at 90Nm, fed by an integrated 630Wh Fantic Integra battery and controlled through the Brose All Round 4 display.
The build is sensibly utilitarian rather than flashy: a RockShox Recon Silver RL fork and Deluxe Select air shock, SRAM SX Eagle 12-speed shifting, SRAM Level 2-piston brakes on 200/180mm rotors, and Schwalbe Smart Sam 2.4in tyres on Rodi BlackJack rims. It was offered in three sizes (S, M, L) with a relaxed 66 to 66.5 degree head angle and a 73 degree seat angle.
UK pricing was set at GBP 4,399, sitting it below the higher-specced XTF 1.5 Race and the Brose-powered XTF 1.5 Carbon, as well as the Yamaha-powered All Track and Sport-Y variants in the same family. As an alloy, mid-power trail platform it prioritised value and approachability over light weight or premium kit.
This model year is discontinued; Fantic has since moved the range onto the Shopify-based current catalogue and revised the XTF 1.5 in later years. Specifications here are taken from the archived 2023 manufacturer page and a UK Fantic dealer listing.
Not enough geometry on record to judge size balance.
A workmanlike climber — expect to put in more rider effort on the steep stuff. 560W of peak power and 90Nm of torque — a strong full-power motor.
Lower torque or a slacker seat angle — fine, just don't expect a winch.
How it stacks up vs other Full Power · Trail bikes (from 245 bikes in the database)
| S | M | L | |
| Reach | 407 mm | 433 mm | 453 mm |
| Stack | 573 mm | 602 mm | 627 mm |
| Seattube | 390 mm | 430 mm | 490 mm |
| Headtube Angle | 66° | 66° | 66.5° |
| Seattube Angle (eff) | 73° | 73° | 73° |
| Wheelbase | 1193 mm | 1224 mm | 1244 mm |
| Standover | — | — | 642 mm |
Trims · 1
Base £4,399 | |
| Motor | Brose Drive S Mag · 90 Nm |
| Battery | Fantic Integra 630Wh · 630 Wh |
| Travel F/R | 150/150 mm |
| Frame | Aluminium |
| Fork | RockShox RECON Silver RL e-bike 29" 150mm |
| Shock | RockShox Deluxe Select T205x57,5 Air |
| Stem | GBC alloy stem, 60mm, +/-8 degrees, Oe31.8 |
| Handlebar | GBC alloy handlebar, 760mm, rise 20mm |
| Saddle | Selle Italia Model-X Comfort Superflow 145 |
| Seatpost | Promax telescopic dropper SP-2038 Oe30.9, 80mm (size S) / 100mm (sizes M-L) |
| Brakes | SRAM LEVEL 2-piston hydraulic disc, front and rear, with SRAM CenterLine rotors (200mm front / 180mm rear, 6-hole) |
| Rear derailleur | SRAM SX Eagle 12V |
| Crank | Miranda Delta Isis Q 165mm, with SRAM 34t Steel Eagle chainring |
| Shifters | SRAM SX E-click |
| Cassette | SRAM SX Eagle 12V, 11-50 |
| Chain | SRAM SX Eagle 12V |
| Drivetrain | SRAM SX Eagle 12V; Miranda Delta Isis Q 165mm, with SRAM 34t Steel Eagle chainring; SRAM SX E-click; SRAM SX Eagle 12V, 11-50; SRAM SX Eagle 12V |
| Wheels | Rodi BlackJack TRIP30 wheels |
| Tyres | Schwalbe Smart Sam 29" x 2.4 (front and rear) |
| Price | £4,399 |
Rides similarly
Spot a mistake?
