A solid all-round descender (65.5° head angle, 170mm) — capable in the rough and steep without being an all-out bruiser.
XMF 1.7 2022
Hard-hitting alloy all-mountain with quiet Brose power
The 2022 Fantic XMF 1.7 was the aluminium, full-power member of Fantic's all-mountain XMF line, sitting below the carbon XMF 1.7 Carbon and Carbon Race in the range. It ran a mullet wheel layout (29in front, 27.5in rear) with 170mm of travel at both ends, a slack 65-degree head angle (65.5 on the L) and a 73-degree seat angle, which is firmly enduro-leaning geometry for a bike Fantic still pitched as a trail-handling all-rounder.
Power came from the Brose-based Fantic full-power unit, a Brose S-MAG rated at 90Nm and 250W nominal, fed by an integrated Fantic Integra 720Wh battery for genuinely long-day range. The single Sport build paired a RockShox Domain-R fork and Deluxe Select+ shock with a SRAM NX Eagle 12-speed drivetrain, four-piston SRAM Guide T brakes on 220/200mm rotors, Fulcrum E-700 wheels and Vittoria E-Martello tyres, a hard-wearing all-mountain kit rather than a boutique parts list. Early 2022 builds were specced with a RockShox Yari RC fork and 200mm front rotor before the running change to the Domain-R and 220mm rotor.
It was offered in three sizes (S, M, L) with reach from 425 to 480mm. This is a discontinued 2022 model; Fantic has since moved the XMF on to its newer Integra-era platforms, so availability is now limited to remaining dealer stock and the used market. UK pricing was around £4,999 RRP for the Sport. No independent long-term owner reliability data is collated here.
More planted than poppy — better on steep terrain than tight, fiddly singletrack.
Rear-long with a planted front in L (FC:RC 1.77) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Climbs well — a 73° seat keeps the front planted. 560W of peak power and 90Nm of torque — a strong full-power motor.
Brilliant on fast, rough, steep terrain; less fun on tight, mellow trails.
How it stacks up vs other Full Power · Gravity bikes (from 135 bikes in the database)
| S | M | L | |
| Reach | 425 mm | 454 mm | 480 mm |
| Seattube | 390 mm | 430 mm | 469 mm |
| Chainstay | 459 mm | 459 mm | 459 mm |
| Headtube Angle | 65° | 65° | 65.5° |
| Seattube Angle (eff) | 73° | 73° | 73° |
| Wheelbase | 1241 mm | 1245 mm | 1270.5 mm |
| Headtube | 105 mm | 110 mm | 120 mm |
| BB Height | 363.5 mm | 363.5 mm | 363.5 mm |
| Front Centre | 782 mm* | 786 mm* | 811.5 mm* |
| FC:RC | 1.70 | 1.71 | 1.77 |
Trims · 1
Sport £4,999 | |
| Motor | Brose Drive S Mag · 90 Nm |
| Battery | Fantic Integra 720Wh · 720 Wh |
| Travel F/R | 170/170 mm |
| Frame | Aluminium |
| Fork | RockShox Domain-R e-bike 29" 170mm |
| Shock | RockShox Deluxe Select+ T205x60 Air |
| Stem | FSA Comet, 35mm clamp, +6 degrees, 50mm |
| Handlebar | FSA Comet, 35mm clamp, 15mm rise, 800mm width |
| Saddle | Selle Italia Model-X Comfort Superflow 145 |
| Seatpost | Switch SW dropper, 30.9mm, S-M 100mm / L 125mm |
| Brakes | SRAM Guide T 4-piston hydraulic disc (front and rear). Discs: SramCenterLine 220mm front / 200mm rear, 6-hole. |
| Rear derailleur | SRAM NX Eagle 12-speed |
| Crank | FSA CK-7462/IS 165mm with SRAM 34t Steel Eagle chainring |
| Shifters | SRAM NX E-click |
| Cassette | SRAM SX Eagle 12-speed, 11-50 |
| Chain | SRAM SX Eagle 12-speed |
| Drivetrain | SRAM NX Eagle 12-speed; FSA CK-7462/IS 165mm with SRAM 34t Steel Eagle chainring; SRAM NX E-click; SRAM SX Eagle 12-speed, 11-50; SRAM SX Eagle 12-speed |
| Wheels | Fulcrum E-700 wheels |
| Tyres | Vittoria E-Martello, front 29"x2.35 / rear 27.5"x2.6 |
| Price | £4,999 |
Rides similarly
Spot a mistake?
