Bike Finder · Fantic
Fantic XEF 1.8
Fantic
XEF 1.8 2023
DiscontinuedFull Power · GravityLegacy · 0.2/10iFreshness 0.2/10
Travel F/R
180/180mm
Wheels
MX (29F / 27.5R)
Frame
Aluminium
Weight
Price
£5,699
View the Fantic XEF 1.8 on Fantic’s site
Fantic XEF 1.8 2023
From £5,699
EMTB Forums verdict
The Fantic XEF 1.8 Sport was the alloy entry point into the Italian brand's 2023 enduro e-bike line, the descendant of the award-winning XF1 Integra 180. It ran 180mm of travel front and rear on a mixed-wheel chassis, a 29in RockShox Domain R fork paired with a coil SuperDeluxe Coil Select+ shock, and slack 64 to 64.5 degree head angles across the three frame sizes.
Power came from the Brose S-Mag motor rated at 90Nm, fed by a 720Wh semi-integrated Fantic battery, with a Brose Remote at the bar. The build leaned on hard-wearing rather than flashy kit: a SRAM NX Eagle 12-speed drivetrain with an SX cassette, SRAM Code R four-piston brakes on a 220mm front and 203mm rear rotor, Mavic E-Deemax wheels and burly Vittoria E-Mazza and E-Martello rubber.
Geometry was long and low for its day, with reach growing from 414mm on the S to 469mm on the L, 459mm chainstays throughout and a 364mm bottom bracket height. It is a coil-sprung, long-travel alloy enduro machine built for steep, technical descending rather than light weight.
This 2023 model is discontinued; it was superseded by later XEF 1.8 and 1.9 versions. Specifications above are taken from the archived 2023 Fantic product page.
Geometry read
Size
Descending
78
Slack 64.5° head angle, 180mm travel and a long 1281mm wheelbase — composed in the chunk, confident when it gets steep, and stable through fast corners.
Playfulness
17
More planted than poppy — better on steep terrain than tight, fiddly singletrack.
Size balance
98
Rear-long with a planted front in L (FC:RC 1.79) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
66
Climbs well — a 72° seat keeps the front planted. 560W of peak power and 90Nm of torque — a strong full-power motor.
Best suited toFast, steep, rough tracks — and riders who want maximum composure.
Rewards commitment; it should feel calmer as the speed rises.
Watch out forNot a flickable, playful bike — built to plough, not pop.
Brilliant on fast, rough, steep terrain; less fun on tight, mellow trails.
How it stacks up vs other Full Power · Gravity bikes (from 117 bikes in the database)
Battery720 Whabout average capacity
Motor torque90 Nm13 Nm below average
Value for money72/100from £5,699 · most Brose Drive S Mag bikes ~£6,699
Bike geometry diagram
SML
Reach414 mm443 mm469 mm
Seattube390 mm430 mm470 mm
Chainstay459 mm459 mm459 mm
Headtube Angle64°64°64.5°
Seattube Angle (eff)72°72°72°
Wheelbase1226 mm1256 mm1281 mm
Headtube105 mm110 mm120 mm
BB Height364 mm364 mm364 mm
Front Centre767 mm*797 mm*822 mm*
FC:RC1.671.741.79
Trims · 1
Sport
£5,699
MotorBrose Drive S Mag · 90 Nm
BatteryFantic Integra 720Wh · 720 Wh
Travel F/R180/180 mm
FrameAluminium
ForkRockShox Domain R 180mm (e-bike, 29")
ShockRockShox SuperDeluxe Coil Select+ (205x65)
StemFSA Comet 35mm, Ø35, Rise +6°
HandlebarFSA Comet 800mm, Ø35, Rise 25mm
SaddleSelle Italia Model-X Comfort Superflow 145
SeatpostSwitch SW Ø30.9 (dropper)
BrakesSram Code R 4-piston disc brake (front and rear); Braking S3 Battfly rotors 220mm front / 203mm rear (6-bolt)
Rear derailleurSram NX
CrankFSA crank arm with Sram 34t chainring
ShiftersSram NX Eagle
CassetteSram SX, 12V, 11-50
ChainSram NX
DrivetrainSram NX; FSA crank arm with Sram 34t chainring; Sram NX Eagle; Sram SX, 12V, 11-50; Sram NX
WheelsMavic E-Deemax 29" / 27.5"
TyresVittoria E-Mazza 29"x2.6 (front); Vittoria E-Martello 27.5"x2.8 (rear)
Price£5,699
Rides similarly
Spot a mistake?
