E-Troy 2025
Bosch SX-powered mullet trail eMTB, Split Pivot suspension, 400Wh battery
The Devinci E-Troy 2025 is a Canadian-built aluminium all-mountain eMTB sold in two distinct flavours: the full-power GX with Bosch Performance Line CX (160/150 mm travel, 24.7 kg) and the lightweight Lite GX with Bosch SX (19.1 kg). Headline numbers across the platform: 160 mm front, 150 mm rear, an adjustable 64.0 to 64.7 degree head angle via the bike's High/Low flip-chip, eight effective size options across four physical sizes, and a £5,999 base GX price. The community read on the Lite variant is largely positive, with Bosch SX climbing strong and range comfortably matching mid-tier full-power rivals.
Drive system and range. The GX is built around the Bosch Performance Line CX, a proven full-power unit with strong dealer support and the new Gen 5 firmware refinements available across the line. The Lite GX swaps the heavier CX for the lightweight Bosch SX at 55 Nm and 2.0 kg. fredmotokx measured real-world range on the E-Troy Lite at roughly 800 m vertical climbing on eMTB mode from full charge to zero, 1,000 m in E-tour, and 650 m in Turbo, which is competitive with most 400 Wh lightweight rivals. Emailsucks98 rates the SX as "more power than a Trek Fuel EXe, slightly better range, but louder than a TQ, and with a non-removable battery". jayx4 reports zero issues at 300 miles on the SX-equipped Lite.
Geometry and handling. Devinci uses a Split Pivot rear suspension layout and the bike has a High/Low flip-chip that flips between two distinct geometry numbers per size. Reach progresses from 440 mm (SM Low) through 460 mm (MD), 480 mm (LG) to 500 mm (XL Low), with the High setting shortening chainstay (432 to 442 mm) and steepening the head angle to 64.7 degrees. Low gives 64.0 degree HA with slightly longer chainstays (435 to 445 mm). Wheelbase grows from 1,204 mm in SM up to 1,289 mm in XL Low. The 432 to 445 mm chainstay range is genuinely short for an all-mountain platform, which biases the bike towards lively, manual-friendly handling without sacrificing high-speed composure.
Build and value. Two trims are on file: the GX at £5,999 (full-power, 24.7 kg, alloy) and the Lite GX at £7,499 (lightweight, 19.1 kg, Fox 36 Performance Elite fork, Fox Float X Elite shock, SRAM Code Bronze brakes, SRAM GX mechanical Eagle 12-speed). fredmotokx upgraded the Magura MT5 brakes (on a different Lite trim) to Hayes Dominion A4 and swapped the front tyre to Maxxis Assegai MaxGrip EXO+ as first priorities, suggesting the stock brakes and tyres are the weak link on entry builds.
Community-verified strengths. First, well-judged geometry: e-rico calls the E-Troy "very responsive and fast handling" for the travel, noting the slack head angle is "a little floppy at slow speeds but not noticeable at speed". Second, climbing comfort: the same rider notes power assist is "better at slower cadences of 70 to 80 rpm". Third, drivetrain reliability: jayx4 reports zero problems at 300 miles.
Caveats and known gripes. First, motor noise on the SX variant: Emailsucks98 reports a developed "subtle rattle" after a dozen rides on the Lite. Second, motor-mount creak issues — multiple riders chasing creaks have ended up changing the motor mounting sleeves to permanently fix them. Third, the Lite's non-removable battery, called out by Emailsucks98, limits charging convenience.
Verdict. The Devinci E-Troy 2025 is a strong pick for riders who want a Canadian-built alloy all-mountain platform with thoughtful adjustable geometry, choosing between full-power (GX) and lightweight (Lite GX) based on terrain and riding style. Less suitable for buyers chasing carbon frame weights, premium stock brakes, or motor variants outside the Bosch family. Production status: current.
| LG High | LG Low | MD High | MD Low | SM High | SM Low | XL High | XL Low | |
| Reach | 488 mm | 480 mm | 469 mm | 460 mm | 449 mm | 440 mm | 508 mm | 500 mm |
| Stack | 624 mm | 631 mm | 615 mm | 622 mm | 606 mm | 613 mm | 633 mm | 640 mm |
| Chainstay | 442 mm | 445 mm | 432 mm | 435 mm | 432 mm | 435 mm | 442 mm | 445 mm |
| Headtube Angle | 64.7° | 64° | 64.7° | 64° | 64.7° | 64° | 64.7° | 64° |
| Seattube Angle (eff) | 77.2° | 76.4° | 78.6° | 77.8° | 78.9° | 78.1° | 77° | 76.2° |
| BB Drop | 20 mm | 31 mm | 20 mm | 31 mm | 20 mm | 31 mm | 20 mm | 31 mm |
| Wheelbase | 1263 mm | 1265 mm | 1228 mm | 1230 mm | 1204 mm | 1206 mm | 1287 mm | 1289 mm |
| Headtube | 115 mm | 115 mm | 105 mm | 105 mm | 95 mm | 95 mm | 125 mm | 125 mm |
| Standover | 747 mm | 737 mm | 747 mm | 737 mm | 747 mm | 737 mm | 747 mm | 737 mm |
| Front Centre | 821 mm | 820 mm | 796 mm | 795 mm | 772 mm | 771 mm | 845 mm | 844 mm |
Trims · 2
GX £5,999 | Lite GX £7,499 | |
| Motor | Shimano EP801 | Bosch Performance Line SX |
| Battery | Bosch PowerTube 625 · 625 Wh | Bosch CompactTube 400 · 400 Wh |
| Travel F/R | 160/150 mm · all trims | |
| Frame | Aluminium · all trims | |
| Fork | Fox 38 Performance Elite Grip2 160 | E-Optimized | 44 Offset | Fox Float 36 Performance Elite, 160mm travel |
| Shock | Fox Float X Performance Elite Evol LV | 0.4VSpacer | 185x55T | Fox Float X Performance Elite, trunnion mount, 185x55mm (150mm rear travel) |
| Headset | FSA Orbit 1.5 Zero Stack | FSA Orbit 1.5 Zero Stack (Top ZS44 / Bottom ZS56) |
| Stem | V2 Pro | B:35mm | L:50mm | 0° | Devinci V2 Pro, 40mm length |
| Handlebar | V2 Pro | B:35mm | R:30mm | W:800mm | Race Face Turbine R, 800mm width, 35mm rise |
| Grips | Devinci Performance, w/lock-on | Devinci Performance lock-on |
| Saddle | SDG BELAIR Max eMTB | SDG Bel-Air Max eMTB |
| Seatpost | SDG Tellis 31.6mm (dropper) | SDG Tellis dropper post (150mm S / 170mm M / 200mm L-XL) |
| Brakes | SRAM Code R | 4 Pistons (front and rear) | SRAM Code Bronze 4-piston hydraulic disc |
| Rear derailleur | SRAM GX Eagle | 12s | SRAM GX Eagle, 12-speed |
| Crank | FSA CK-762 Bosch (crankarm); chainring Sram X-Sync Eagle 34T EMTB | SRAM GX Eagle Alloy, 165mm, with SRAM Eagle X-SYNC 34T chainring |
| Shifters | SRAM GX Eagle 12s Single Click | SRAM GX Eagle Single Click, 12-speed |
| Cassette | SRAM PG1230 | 12s | 11-50T | HG | SRAM NX Eagle PG-1230, 12-speed, 11-50T |
| Chain | SRAM GX Eagle | 12s | SRAM NX Eagle, 12-speed |
| Drivetrain | SRAM GX Eagle 12s | SRAM GX Eagle 12-speed mechanical with NX cassette/chain |
| Wheels | RaceFace Aeffect R30 wheelset; front 29 Boost110x15, rear 27.5 B148x12 HG, 30mm inner | Race Face Aeffect R30 alloy 30mm, mullet 29"/27.5", 12x148 Boost rear |
| Tyres | Front: Maxxis Minion DHF 29x2.5 3C Exo+ TR MaxxTerra; Rear: Maxxis Minion DHR II 27.5x2.4 3C TR DD | Maxxis Assegai 29x2.5" WT front; Maxxis Minion DHR II 27.5x2.4" WT rear |
| Weight | 24.7 kg | 19.1 kg |
| Price | £5,999 | £7,499 |
Rides similarly
Spot a mistake?
