Bike Finder · Devinci
Devinci E-Spartan
Devinci
E-Spartan 2024
CurrentEnduro eMTBLegacy · 2.2/10iFreshness 2.2/10
Bosch SX (60Nm/600W) lightweight freeride/enduro eMTB, made in Canada
Motor
Shimano EP801 · 85Nm · 600W
Battery
BMZ 725 · 725Wh
Travel F/R
170/165mm
Wheels
29F/27.5R
Frame
Aluminium
Weight
21.65 kg
Price
From £4,879
View the Devinci E-Spartan on Devinci’s site
Devinci E-Spartan 2024
From £4,879
EMTB Forums verdict
The Devinci E-Spartan 2024 is the Canadian brand's full-power 29er enduro eMTB, built on a 6061-T6 aluminium frame with Devinci's Split Pivot suspension. It runs a Shimano EP801 motor (85 Nm, 250 W rated, 600 W peak, 2.7 kg) and a removable 725 Wh BMZ pack. Travel is a serious 180 mm front and 170 mm rear, the head angle is a slack 64.0°, and Devinci quotes a 25 kg ride weight. UK availability has historically been limited and the brand operates with strongest dealer support in Canada and the eastern US. @jbrown15 places it cleanly in context: "The Norco Range VLT and Devinci e-Spartan are both 29er long-travel eMTBs with 700 Wh or larger batteries, but use Shimano motors rather than Bosch."
Drive system and range. The Shimano EP801 is the refined version of the long-running EP8, with the same 85 Nm torque and 600 W peak but with re-engineered low-cadence behaviour, quieter operation and proper auto-shift compatibility with Di2 drivetrains. The 725 Wh BMZ pack sits at a sensible midpoint between the 750 Wh standard on most rivals and the 800 Wh now appearing on the latest Bosch and DJI builds. Expect 1,000-1,300 m of climbing depending on assist and rider weight. The pack is removable, making off-bike charging and winter storage straightforward — a meaningful advantage over the integrated batteries on some 2026 competitors.
Geometry and handling. A 64.0° head angle is properly enduro and matches benchmark rivals like the Trek Slash+ (63.7°) and Norco Range VLT (63.5°). Reach progresses S 440 mm, M 460 mm, L 485 mm, XL 505 mm, with a generous 25 mm step from M to L. Chainstay length is fixed at 455 mm across all sizes, which leans the bike toward stability rather than agility. Wheelbase opens from 1,236 mm on the S to 1,314 mm on the XL — long-and-slack figures that confirm the bike's gravity intent. 29in wheels front and rear (no mullet option) reinforce the priority on rollover and high-speed composure over manoeuvrability.
Build and value. The base trim sits at €4,329 in continental Europe and gets the Shimano Deore 12-speed groupset with upgraded Shimano XT brakes — a sensible cost-saving prioritisation given how much of an enduro bike's feel comes from braking power. Suspension on higher trims includes Fox Performance Float 38 forks and Fox DHX2 rear shocks. Devinci offers a separate aluminium Deore build and a higher-spec GX build at slightly different price points depending on market. With its Canadian heritage Devinci sources frames domestically — meaningful for North American buyers concerned about tariffs and supply chain.
Caveats and known gripes. Forum chatter on the E-Spartan itself is thin in the UK and Europe — Devinci's dealer network is heavily Canada-focused, so service, parts and warranty support in Europe is limited. The fixed 455 mm chainstay across all sizes will compromise weight distribution for shorter riders, who will end up sitting further back than ideal. At 25 kg the bike is mid-pack for the category, but neither feathery nor especially heavy. The Shimano EP801 motor has been overshadowed in 2025-2026 headline-spec terms by DJI Avinox (150 Nm) and Bosch CX Gen 5 (120 Nm) — riders chasing maximum punch will look elsewhere, although EP801 reliability and quiet operation remain strong selling points.
Verdict. The Devinci E-Spartan is for riders in North America who want a Canadian-made full-enduro eMTB with proven Shimano EP801 power, removable battery, and properly slack 29er geometry at sensible money. It is not for UK or European buyers without Devinci dealer access, riders chasing the latest 120-150 Nm motors, or smaller riders who want a tighter chainstay. Production status is current with the 2024 model continuing through the start of 2026 alongside the newer 2026-model platform.
Bike geometry diagram
SMLXL
Toptube581 mm604 mm633 mm656 mm
Reach440 mm460 mm485 mm505 mm
Stack625 mm634 mm643 mm652 mm
Seattube400 mm420 mm445 mm485 mm
Chainstay455 mm455 mm455 mm455 mm
Headtube Angle64°64°64°64°
Seattube Angle (eff)77.3°77.2°77.1°77°
Wheelbase1236 mm1260 mm1290 mm1314 mm
Headtube95 mm105 mm115 mm125 mm
Front Centre781 mm805 mm835 mm859 mm
Trims · 2
EAGLE 90 12S
£4,879
GX AXS 12S
£5,999
MotorShimano EP801 · 85 Nm · all trims
BatteryBMZ 725 · 725 Wh · all trims
Travel F/R170/165 mm · all trims
FrameAluminium · all trims
DrivetrainSRAM Eagle 90 12-speed; Bosch SX (60Nm/600W), 400WhSRAM GX AXS Eagle 12-speed; Bosch SX (60Nm/600W), 400Wh
Weight21.65 kg
Price£4,879£5,999
Spot a mistake?
