Bike Finder · Canyon
Canyon Spectral:ON
Canyon
Spectral:ON 2020
DiscontinuedAll-Mountain eMTBLegacy · 0/10iFreshness 0/10
Motor
Shimano STEPS E8000 · 70Nm · 250W
Battery
Shimano STEPS BT-E8035 · 504Wh
Travel F/R
150/150mm
Wheels
mullet (29" front / 27.5" rear)
Frame
Full carbon
Weight
21.35 kg
Price
£6,499
View the Canyon Spectral:ON on Canyon’s site
Canyon Spectral:ON 2020
From £6,499
EMTB Forums verdict
The Canyon Spectral:ON 2020 is a discontinued first-generation 27.5in all-mountain carbon eMTB, built around the Shimano STEPS E8000 motor (70 Nm, 250 W rated, 2.89 kg) and an integrated 504 Wh Shimano BT-E8035 battery. Travel is 150 mm front and rear via a four-bar layout, head angle 66.5°, and Canyon quoted 21.35 kg as the claimed weight at launch. Only S and M sizes are listed in the gold spec. Originally retailed at £6,499. As a discontinued five-year-old platform, this is a used-market consideration only — the newer Spectral:ON CF and Neuron:ON CF have since replaced it with bigger batteries, slacker geometry and the latest Bosch CX Gen 5 motors. Used Spectral:ON 2020 bikes typically sit at £2,000-3,000 depending on condition.
Drive system and range. The Shimano STEPS E8000 was the previous-generation Shimano mountain motor before the EP8 and EP801 took over. It produces 70 Nm of torque — modest by 2025 standards (compare the modern EP801 at 85 Nm or Bosch CX Gen 5 at 120 Nm). Operation is smooth and proven but the motor has a known "rattle" complaint at coast on certain firmware revisions. The 504 Wh battery is small by current standards (most rivals now run 625-800 Wh), and the bike's BT-E8035 pack is integrated and non-removable, which complicates off-bike charging and winter storage. Real-world range is roughly 60-90 km depending on assist and terrain. No Bluetooth on the original E-Tube spec.
Geometry and handling. A 66.5° head angle was conservative even in 2020 and now feels dated against modern 64-65.5° rivals. Reach progresses S 425 mm, M 445 mm — only two sizes is a notable restriction, suiting riders typically 5'3"-5'9". Chainstay length is fixed at 435 mm, which is short and helps the bike feel agile. Wheelbase 1,171-1,197 mm. The original Spectral:ON ran full 27.5in wheels rather than the mullet or 29in configurations now common; the 2020 model is firmly in the older-generation geometry category.
Build and value. Canyon offered the 2020 Spectral:ON across multiple trims at launch, with components scaling from Shimano Deore/SLX 11-speed and SR Suntour or RockShox Yari forks on the entry-level CF 6 through to Fox 36 Performance/Factory forks, Fox Float DPX2 shocks and Shimano XT/XTR drivetrains on the higher CF 8 and CF 9 trims. The £6,499 starting price reflects the carbon frame premium at the time — comparable bikes now sit at higher real-money figures due to inflation. The integrated battery, headset cable routing on some variants and Canyon's direct-to-consumer model made the platform polarising even at launch.
Caveats and known gripes. The biggest issues with the 2020 Spectral:ON are well-documented across the forum and broader internet: the non-removable battery is a hassle for off-bike charging, the small 504 Wh capacity limits range, and the conservative 66.5° head angle limits descending capability. @rider references a known issue: "high and can lead to shock failures" — Canyon historically flagged shock-shaft incompatibility for some coil-shock conversions on the CFR variant. The Shimano STEPS E8000 motor is now obsolete and replacement requires going to second-hand units or upgrading to a newer Shimano motor (with associated wiring complications). Canyon's direct-to-consumer service model means service is courier-based, which adds time when issues arise. Two sizes only means many riders are forced into a less-than-ideal fit.
Verdict. The 2020 Canyon Spectral:ON is for the budget-focused used-market buyer who wants an aluminium-or-carbon trail eMTB at a sub-£3,000 price point and is comfortable with older Shimano STEPS technology and Canyon's direct-to-consumer service. It is not for buyers who want modern slack geometry, removable batteries, the latest motor torque figures, or larger-than-S/M frame sizes. Production status: discontinued. Canyon has moved on through the Spectral:ON CF and Neuron:ON CF generations, and 2020-spec bikes are now a used-market proposition only.
💬 Forum discussion
Important safety note from Canyon: the Spectral:ON CF / CFR and Torque:ON CF models may have damage to the battery
639 replies · 150.8k views · last reply 3 weeks ago
Join the discussion →
“I did return. Just a new Orbea Wild owner...”
— txominsabin · ♥ 9 · most-liked post
OWNERS’ REPORT
Canyon Spectral:ON — what owners actually know
3,069 posts · 578 owners · data through Feb 2026
50LEGACY (EP8/EP801 era, 2022-2025): battery recall - cracked casings on ALL 720/900Wh Spectral:ON CF/CFR batteries (Nov… · typical onset: Recall notice 2024-11-06.
12LEGACY (E8000 era, 2018-2021): shock-extension plastic bushings and budget pivot bearings fail early · typical onset: Bushings: 250-1,600km.
6LEGACY (E8000 + EP8 eras): lower headset bearing/cup encased Block Lock design, and 2023-era cups effectively glued in · typical onset: When the lower bearing dies - wet-climate bikes within 1-2 winters
16,000km Neuron:ON/Spectral:ON family bike still on its ORIGINAL shock bushings - owner washes the pivot area with a damp cloth only
Inside: the community setup plate · numbered field notes · the used-buyer checklist.
Read the full owners’ report →
Bike geometry diagram
SM
Reach425 mm445 mm
Stack620 mm625 mm
Chainstay435 mm435 mm
Headtube Angle66.5°66.5°
Seattube Angle (eff)74.5°74.5°
BB Drop33 mm33 mm
Wheelbase1171 mm1197 mm
Headtube100 mm115 mm
Standover784 mm788 mm
Front Centre736 mm762 mm
Trims · 1
Base
£6,499
MotorShimano STEPS E8000 · 70 Nm
BatteryShimano STEPS BT-E8035 · 504 Wh
Travel F/R150/150 mm
FrameCarbon
SaddleCanyon SD:ON
TyresMaxxis Minion DHF 29x2.5 EXO TR front / Maxxis Minion DHR II 27.5x2.6 rear
Weight21.35 kg
Price£6,499
Rides similarly
Spot a mistake?
