Bike Finder · BH
BH AtomX Lynx Pro
BH
AtomX Lynx Pro 2025
CurrentEnduro eMTBMature · 5.5/10iFreshness 5.5/10
Travel F/R
160/160mm
Wheels
29F / 29R
Frame
Full carbon
Price
From £5,699
View the BH AtomX Lynx Pro on BH’s site
BH AtomX Lynx Pro 2025
From £5,699
EMTB Forums verdict
The BH AtomX Lynx Pro is the brand's flagship carbon enduro platform, built around 160mm of travel front and rear, full 29in wheels and a Split Pivot rear end. The Brose S Mag motor delivers 90 Nm from a magnesium housing, fed by a 720Wh integrated battery, so it sits in the full-power, full-fat enduro class rather than the lightweight category. Geometry is squarely modern enduro: a 65 degree head angle, 76 degree seat angle, consistent 454mm chainstays across all four sizes and a reach that runs from 423mm on the S to 485mm on the XL.
The three Pro builds all share the same carbon frame, motor, battery and geometry, so the choice is purely about component grade. The 9.9 (6,649.90 GBP) tops the range with a FOX 38 Factory fork, FOX FLOAT DHX2 Factory shock, full Shimano XT shifting and DT Swiss H1700 wheels. The 9.8 (6,174.90 GBP) keeps the XT rear mech and Shimano four-piston brakes but steps to a FOX 38 Performance fork, FLOAT X shock, SLX shifters and H1900 wheels, which is the value sweet spot of the line. The 9.7 (5,699.90 GBP) holds the XT derailleur and 160mm FOX 38 chassis while saving money with a Rhythm fork, DPS shock, Deore shifters, MT520 brakes and Race Face AR30 rims.
Across the board the kit is consistent and sensibly chosen: 203mm rotors front and rear, a Praxis crank, Maxxis Minion tyres, Race Face Aeffect cockpit and a BH i-Remote with iConnect app and Garmin connectivity. Every Pro size from S to XL is offered, and BH notes the forward motor position gives a low standover even on the smallest frame.
Bike geometry diagram
SMLXL
Reach423 mm450 mm470 mm485 mm
Stack621 mm625 mm634 mm648 mm
Seattube390 mm410 mm440 mm480 mm
Chainstay454 mm454 mm454 mm454 mm
Headtube Angle65°65°65°65°
Seattube Angle (eff)76°76°76°76°
Headtube95 mm100 mm110 mm125 mm
BB Height346 mm346 mm346 mm346 mm
Trims · 3
9.7
£5,699
9.8
£6,174
9.9
£6,649
MotorBrose Drive S Mag · 90 Nm · all trims
BatteryBrose 720 · 720 Wh · all trims
Travel F/R160/160 mm · all trims
FrameCarbon · all trims
ForkFOX 38 FLOAT Rhythm 160mm 15QRFOX 38 FLOAT Performance 160mm 15QRFOX 38 FLOAT Factory 160mm 15QR
ShockFOX FLOAT DPS PerformanceFOX FLOAT X PerformanceFOX FLOAT DHX2 Factory
HeadsetAcros AIF-560 ICR BL. · all trims
StemBH Evo 35 Fit · all trims
HandlebarRace Face Aeffect Riser 35 780mm · all trims
GripsErgon GE10Ergon GE10Ergon GE1-Factory
SaddlePrologo Proxim W350 StnPrologo Proxim W450 StnPrologo Proxim W450 Stn
SeatpostRace Face DP Aeffect 31.6 · all trims
BrakesShimano MT520 4 Piston (front and rear)Shimano XT 4 Piston (front and rear)Shimano XT 4 Piston (front and rear)
Rear derailleurShimano XT 12sp · all trims
CrankPraxis 32T-165mm · all trims
ShiftersShimano DeoreShimano SLXShimano XT
CassetteShimano CSM6100 12sp (10-51T)Shimano CSM7100 12sp (10-51T)Shimano CSM8100 12sp (10-51T)
ChainShimano CNM6100 · all trims
DrivetrainShimano XT 12sp; Praxis 32T-165mm; Shimano Deore; Shimano CSM6100 12sp (10-51T); Shimano CNM6100Shimano XT 12sp; Praxis 32T-165mm; Shimano SLX; Shimano CSM7100 12sp (10-51T); Shimano CNM6100Shimano XT 12sp; Praxis 32T-165mm; Shimano XT; Shimano CSM8100 12sp (10-51T); Shimano CNM6100
WheelsRace Face Ar 30 TR (BH hubs, stainless steel spokes)DT Swiss H1900 TR (DT Swiss hubs, stainless steel spokes)DT Swiss H1700 TR (DT Swiss hubs, stainless steel spokes)
TyresMaxxis Minion TPI120 Terra EXO TR 29x2.5/2.4 · all trims
Price£5,699£6,174£6,649
Rides similarly
Spot a mistake?
