A solid all-round descender (66° head angle, 140mm) — capable in the rough and steep without being an all-out bruiser.
AtomX Lynx Pro 2023
The BH AtomX Lynx Pro is the trail-oriented build of BH's AtomX Lynx platform for 2023, running 140mm of travel front and rear on 29in wheels. The frame is the AtomX Lynx carbon chassis with an alloy rear triangle (BH lists it verbatim as '140mm Full Susp. Carbon 29in Internal Cable Routing, Acros ICR / Alloy Rear Triangle'), which sits a step below the full-carbon AtomX Lynx Carbon Pro models that share the same 140mm travel but use a full-carbon back end. Power comes from the Brose S Mag motor, badged by BH under its 'X System', a magnesium-bodied unit rated at 90 Nm fed by a 720Wh integrated battery with a claimed range of up to 155 km.
Geometry is sensible rather than extreme for the era: a 66 degree head angle, 77 degree seat angle, 455mm chainstays across the range and reach from 428mm (S) to 490mm (XL), with stack climbing from 603mm to 630mm. Two trims were offered. The 8.2 (£5,699.90) pairs a RockShox Recon RL fork and Deluxe shock with an 11-speed Shimano Deore drivetrain and MT420 four-piston brakes on 203mm rotors. The 8.4 (£6,299.90) steps up to a FOX 34 Float Rhythm fork, FOX Float DPS Performance shock and a 12-speed cassette, sharing the same four-piston brakes and BH finishing kit.
This bike is discontinued. BH rebranded the AtomX Lynx line to the iLynx range from 2024 onwards, so the 2023 AtomX Lynx Pro is the last of the AtomX-badged trail bikes. Anyone cross-shopping it today should note it is a carbon-front bike with an alloy back end, not a full-alloy frame, and that the later iLynx supersedes it.
More planted than poppy — better on steep terrain than tight, fiddly singletrack.
Not enough geometry on record to judge size balance.
Climbs well — a 77° seat keeps the front planted. 560W of peak power and 90Nm of torque — a strong full-power motor.
Brilliant on fast, rough, steep terrain; less fun on tight, mellow trails.
How it stacks up vs other Full Power · Trail bikes (from 246 bikes in the database)
| S | M | L | XL | |
| Reach | 428 mm | 455 mm | 475 mm | 490 mm |
| Stack | 603 mm | 607 mm | 616 mm | 630 mm |
| Seattube | 410 mm | 420 mm | 440 mm | 480 mm |
| Chainstay | 455 mm | 455 mm | 455 mm | 455 mm |
| Headtube Angle | 66° | 66° | 66° | 66° |
| Seattube Angle (eff) | 77° | 77° | 77° | 77° |
| Headtube | 100 mm | 100 mm | 110 mm | 125 mm |
| BB Height | 340 mm | 340 mm | 340 mm | 340 mm |
Trims · 2
Pro 8.2 £5,700 | Pro 8.4 £6,300 | |
| Motor | Brose Drive S Mag · 90 Nm · all trims | |
| Battery | BH ATOMX integrated 720Wh · 720 Wh · all trims | |
| Travel F/R | 140/140 mm · all trims | |
| Frame | Carbon (alloy rear triangle) · all trims | |
| Fork | Rock Shox Recon RL 140mm 15QR | FOX 34 FLOAT Rhythm 140mm 15QR |
| Shock | Rock Shox Deluxe Debonair | FOX FLOAT DPS Performance |
| Headset | Acros AZX-581 BL. · all trims | |
| Stem | BH Evo 35 Fit · all trims | |
| Handlebar | BH Lite 35 780mm · all trims | |
| Grips | Ergon GE10 · all trims | |
| Saddle | Prologo Proxim W350 Stn · all trims | |
| Seatpost | Race Face DP Aeffect 31,6 · all trims | |
| Brakes | Shimano MT420 4 Piston (front and rear), 203mm rotors | Shimano MT420 4 Piston (front and rear) |
| Rear derailleur | Shimano Deore 11sp · all trims | |
| Crank | Praxis 34T-165mm · all trims | |
| Shifters | Shimano Deore · all trims | |
| Cassette | Shimano CSM5100 11sp (11-51T) | Shimano CSM6100 12sp (10-51T) |
| Chain | Shimano HG60 | Shimano CNM6100 |
| Drivetrain | Shimano Deore 11sp; Praxis 34T-165mm; Shimano Deore; Shimano CSM5100 11sp (11-51T); Shimano HG60 | Shimano Deore 11sp; Praxis 34T-165mm; Shimano Deore; Shimano CSM6100 12sp (10-51T); Shimano CNM6100 |
| Wheels | Race Face Ar 30 TR · all trims | |
| Tyres | Maxxis Minion TPI120 Terra EXO TR 29"X2,5/2,4 · all trims | |
| Price | £5,700 | £6,300 |
Rides similarly
Spot a mistake?
