Shimano EP8 (801) VS Bosch Performance CX review - which is stronger?
We’ve tested and ridden both motors several times before. But we decided to do a new comparison of these motors as they’ve changed quite a bit since they were launched.
Changes to the Bosch Performance CX​
Our first ride on the Bosch Performance CX gen 4 happened well into 2019. This nice and compact motor weighs just under 3 kg and was rated at 75 Nm. It didn’t take long before Bosch dropped a software update for the Performance CX, taking it up to 85 Nm.
Riding with maximum assistance, the CX motor was a tad twitchy to control on technical trails. It immediately got a reputation for being a powerful motor that responded well to high pedaling frequencies. It felt strong while riding at motor cut-off speed.
Oh no, what happened to the Performance CX badge on the motor?? (:
In 2021, Bosch introduced the Smart System refresh. The motor appeared unaltered as looks and specs remained the same. Smart System brought things like new batteries, a GPS module plus new displays and remotes with Bluetooth support.
But that was not all. I was surprised to discover the CX gen 4 motor was now much easier to control in Turbo mode. The motor felt so pleasant and well behaved while remaining just as powerful.
Pedal damn it
Changes to the Shimano EP8​
Late 2020, Shimano launched the EP8 (EP800). This was a more compact and lighter motor at just under 2.7 kg. It was a very well-behaved and could be ridden on wet and rocky trails with maximum assistance. The EP8 felt very strong at lower speed and we could ride steep hills with little effort. But as we pedaled faster and approached cut-off speed, this motor didn’t feel as fast. It turned out the EP8 would cut the assistance about 1 kph earlier than the Bosch, and the EP8 felt less powerful at high cadence.
Two and a half years later, Shimano introduced the refreshed EP801. The old EP8 had earned a reputation for not being among the most reliable. So, when Shimano needed to add hardware for automatic shifting to the motor, they took the opportunity improve it.
The latest Shimano EP8 motor is often referred to as the EP801.
The EP801 is still an 85 Nm motor, but Shimano claims peak power is up from 500 to 600 W. And that can be felt. The EP8 has become more powerful and inspiring to ride when pedaling above 90 rpm. Motor cut-off speed has been increased to match the Bosch CX and most others. Thankfully, the Shimano motor remains just as generous and easy to control on slippery trails. And it seems durability is improved too.
Both have improved significantly​
Based on previous experience, the EP8 was stronger pedaling below 80 rpm while the Bosch was stronger above 80. And when going on group rides and riding at around cut-off speed on the transport sections, it was more work riding the EP8 as motor power cut earlier. But now, all of this has changed! They’re equally as fast on the transport sections, and they’re both very good on technical trails with maximum assistance.
The Shimano EP801
About the test​
So, how do we determine which is stronger? There are two sides to this, peak power and power amplification. If we ride uphill in a low gear while pedaling slowly, we’re not getting maximum power. This is a test of power amplification. If we push hard, we’ll be limited by the peak power. It’s interesting testing both. Before we start, we make sure that both motors are set to the highest power settings in the app, Both bikes were set to the highest assistance mode.
Advanced pedal mount technique
We decided to do an uphill test in the lowest gear. Both bikes have 29er wheels and a 34-51t gear ratio. The hill is about 100 m long with 20 m of elevation, and we rode it at 60, 80 and 100 cadence. We measured how hard the rider pedaled using Garmin Rally pedals. If the rider puts less force to the pedals, we know the motor has done more of the work as both bikes completed the segment in the same time with similar cadence.
Finally, we did a short trail loop of just under one kilometer. The loop starts with a section of smooth surface where we briefly went above cut-off speed, before entering rocky and rooty trails. There is little difference in elevation. We went all out on this test and we only measured time. We tried measuring power input, but there was just too much variation in the average power caused by things like gear choice and time above motor cut-off. It’s a less precise test, but it’s interesting to see if we could find huge, significant differences.
Mounting Garmin Rally power pedals on the Orbea Wild H10.
Mounting a Garmin computer on the BESV TCA 1.1.
Uphill test​
60 cadence results​
Riding with a cadence of 60 felt much easier on the EP8 (801), and the numbers reflected this. We had to pedal 95 W on the CX, that’s almost 50% more than the EP8 which required 65 W. For real life riding, it doesn't make much difference though, it took little effort going up this steep hill with both motors.
80 cadence results​
Based on previous experience, we expected the motors to be similar when pedaling 80 rpm. But the difference still was huge, the EP8 required an average rider input of 71 W while the CX needed 115 W.
100 cadence results​
Spinning as fast as 100 rpm, we actually recorded the exact same power input of 154 W for both motors. This was surprising as the CX used to be more powerful when pedaling faster.
Short trail loop results​
When riding as fast as possible on trails with little elevation, there wasn’t much of a difference between them. It was difficult achieving a high cadence when pedaling over chunky and bumpy terrain, so the EP8 had an advantage as it’s more generous at lower cadence. But when we got to spin the pedals at 100+ rpm, the CX felt stronger. According to Strava, the CX clocked in at 1 min 42 seconds, a whole second quicker than the EP8. It’s hard to argue the difference is significant. For riding hard, the Bosch felt fast, and the Shimano felt much improved over the old EP800.
Riding flat-out on the test loop.
Which motor is more efficient?​
Shimano has a reputation of being less efficient and draining the battery quickly. But is that due to efficiency? This test shows the EP8 offers more support, which means power consumption will be higher. It might not be less efficient; it just does more of the work.
Conclusion​
The EP8 won the lower cadence tests because of the high power-amplification, it’s rated at 400% compared to the 340% for Bosch. When pedaling faster and harder, both motors reached their peak power of about 600 W and performance was similar.
The EP801 is greatly improved. It feels like a very complete motor. The CX is still great, but one could argue the slightly older and slightly heavier Bosch has a bit of catching up to do.
Some random data.
About author
knut7
Started mountainbiking in the 90s. Moved to emtbs in 2014 and have been reviewing them since 2016. Contact me here https://emtb.no/contact/
Comments
With all the subjective comparisons of power it would be cool to see someone do a head to head comparison of power output from at least the big 3 of Bosch, Shimano, and Specialized/Brose.
Without any of them having a throttle, a dyno would probably be tough, but something inline between the battery and controller to watch current draw would probably be the next best thing, I believe Luna did a video like this of a Turbo Levo and showed it exceeded the rated power by a good amount. I haven’t seen anything similar for Bosch or Shimano, it would be interesting to see them all compared together in the same test. Could throw in some others as well.
It's not just about pottering about the trails or woods. Many of us commute and carry loads. So I'd like to see carry capacity/range be a strong factor in comparisons.
@knut7 , this is an excellent and thorough test. Well done.
I assume that you kept each bike in the same gear for each cadence level, in which case you are fixing speed and total system power output (motor + person), which enables you to see how much extra effort is required or how much less power the motor is putting in.
You make a good point about efficiency, as the rider is putting in more effort. It would be good to test this though. Sam's bikes did a great range test and showed the Bosch to absolutely kill the Shimano. If the Shimano is less efficient then what you save in motor weight you gain in battery mass for a given range, but maybe it's not?!
I would expect the efficiency of all these systems to be very close, they’re a brushless motor powering a bike wheels through some gears and a chain. The efficiencies of the motors are going to be extremely close between any of them, they really don’t vary much. The perceived efficiency differences are much more likely a result of one offering more assist than another at different levels and humans not being that good at knowing the difference. The true efficiency of the mechanical and electrical systems should be within a percentage or two of one another.
@RoJo Thanks! Yeah, the bikes were ridden in the lowest gear (34-51) for 60, 80 and 100 rpm. Same rider for all runs.
To me, it seems difficult to say anything about efficiency. It's difficult reading battery state-of-charge with more precision than 1%, so the test loop/hill needs to be quite long to minimize the effect of the battery charge readout precision. And the BMS might report the SOC linearly, or just based on battery voltage. If you're able to go at the same speed with the same rider input for long enough, then I guess you could get some useful data. You could always measure the power you put into the battery when recharging it, to avoid relying on the SOC reported by the BMS.
I agree with @xtraman122 , these motors should have very similar efficiency. But ebike motors probably have different internal gearing and the coils are probably wound differently, so different motors might be the most efficient at various cadence. Which ads to the complexity of the test. I guess some motors might be most efficient at an "unfortunate" cadence range. And I guess there there is room for efficiency loss in the motor programming. This is just speculation and all of this might not affect the efficiency significantly.
Huge hill and do as many laps as it takes to deplete the battery at constant cadence (I say this jokingly because I know what effort this kind of accurate test takes).
On my E8000 I could only get 800m vert on boost 500Wh but I get 1500m on Bosch race mode 750Wh.
Yep this is a super old Shimano motor, perhaps with a degraded battery but that's a 20% difference in efficiency. I agree that motors should in theory be quite close and all I the upper 90% efficiency range, however there are so many factors to take into account as you point out! Fascinating stuff.
